Activity › Forums › Adobe Premiere Pro › Premiere Pro will only export parts of my sequence
  • Premiere Pro will only export parts of my sequence
    Posted by Samuel Chamalet on July 16, 2015 at 7:59 am
    Hello everyone !
    So I juste tried to export my new project in H264, and for some reasons, two parts of my 5:30 sequence won’t render. They show up as this :
    The first part that doesn’t render is a 5 seconds title I made in After Effects that comes up just after the first sequence. What’s weird is that i got two other clips i edited in after effects, and one more title and they all work perfectly fine. The second one is just a sequence with no editing on any other software what’s so ever, but it shows up the same, and i have no idea why. Their common point is that i can see them in the timeline when i playback, but when i pause it only shows black.
    If you could save my life, i would be so grateful…. I hope my english is understandable,
    Thanks in advance.
    Samuel Chamalet replied 11 years, 2 months ago 2 Members · 2 Replies
  • Chris Tompkins
    July 16, 2015 at 5:58 pm
    A couple of things to try;
    Copy all footage to a new sequence.
    Export direct from Pr instead of queue send to Me.
    Render out the AE clips first and import them into the edit.
    Chris
  • Samuel Chamalet
    July 16, 2015 at 6:26 pm
    Thanks for the reply 🙂
    I actually fixed it : I still don’t know why, but for some reasons the colorista III plug-in made this happen. I just deleted the effect layer that was on these clips and it completely fixed the render issue… So I had to find another way to color grade thèse shots, which was pretty annoying, but well, if this problem ever happends to anyone, this might help 🙂
    Cheers
