Activity › Forums › Adobe Premiere Pro › Premiere Pro viewer color issues on Mac displays
  • Premiere Pro viewer color issues on Mac displays
    Posted by Oliver Peters on June 24, 2016 at 12:25 am
    I’m running into a color consistency issue on Macs using Apple displays. This includes older Mac Pros and DVI-connected 27″ Apple displays, as well as new retina iMacs. Using the Apple settings, the Premiere Pro viewer image is more contrasty and saturated than any exported file as viewed in any player app.
    By comparison, my home Mac Pro connected to a Dell display is reasonably close between my viewer and the exported file’s appearance. Of course, the Dell has better set-up options, including controls on the display itself.
    FWIW – on the same machines, I don’t see these sort of differences with FCPX and the exported file.
    Thoughts?
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
    Chris Wright replied 10 years, 3 months ago 2 Members · 2 Replies
  • Oliver Peters
    June 24, 2016 at 11:46 pm
    [Dave LaRonde] “there’s a switch having to do with Mac color displays”
    I don’t believe that’s the case with Premiere – or at least I haven’t found one. There is such a setting in Resolve. However, I have contacted Adobe on this and they are checking into it. Based on some additional testing on various machines, I’m less inclined now to pin the issue on monitor profiles. Rather it appears to have something to do with either color processing through the Premiere pipeline, color handling related to various native codecs, or a combination of the two.
    – Oliver
    Orlando, FL
  • Chris Wright
    June 27, 2016 at 6:06 am
    Try premiere Lumetri lut out Rec. 709 16-235. that should raise the blacks.
    If you knew the gamma, that would help as well. It’s usually 2.2
    or:
    1. calibrate your monitor to one or the other.system preferences>Displays) to 1.8
    2. use gamma tags legacy and in quicktime properties enable FCP legacy
    3. Final Cut Pro/System Settings/Playback Control. Change Gamma Correction from
    Accurate to Approximate
    4. fcp individual clips – Editing tab, “Imported Still / RGB Video Gamma”. choose
    source 1.80, 2.20
    4. use icm or luts to counter.
    some further thoughts…
    you can setup your monitor profiled at gamma 1.8/2.2
    You should think about editing your working LUT to your native monitor gamma.
    If you want to stick with gamma 1.8, continue reading.
    1. for playback, QuickTime preference, General tab:
    “Enable Final Cut Studio colour compatibility”
    2. in AE,
    Choose File > Project Settings. “Legacy Quicktime Gamma” preference via render
    queue, not export
    https://helpx.adobe.com/after-effects/kb/quicktime-movies-too-dark-light.ht...
    3. there’s quicktime 1.8 iluts in speedgrade/premiere as well.
