Activity › Forums › Adobe Premiere Pro › Premiere Pro – View video in different tracks on Timeline on separate program monitors?
  • Premiere Pro – View video in different tracks on Timeline on separate program monitors?
    Posted by Björn Johansen on December 14, 2018 at 6:16 am
    Hi all
    I have two layers of video. One is on V1, the other on V2. Two cameras covering different parts/locations of the same event.
    Is there a way to view the material simultaneously without having to make a multicamera sequence?
    Warm regards
    Björn
    John Pale replied 7 years, 9 months ago 3 Members · 3 Replies
  • John Pale
    December 14, 2018 at 1:12 pm
    No NLE does that. You need dedicated multi stream playback software for that job. Use the right tool for the job.
  • Mike Cohen
    December 14, 2018 at 6:06 pm
    When editing two cameras, I make a PIP of both side by side, make my cuts, then clean it up. Multi-cam will do this too.
  • John Pale
    December 15, 2018 at 2:43 am
    [Mike Cohen] “When editing two cameras, I make a PIP of both side by side, make my cuts, then clean it up. Multi-cam will do this too.
    He’s looking to output each camera on a different monitor simultaneously. Multicam or PIP will output both cameras on the same monitor. He needs two separate streams of video output.
