Activity Forums Adobe Premiere Pro Premiere Pro Update 3.1.1
  • Premiere Pro Update 3.1.1
    Posted by Tclark on December 6, 2007 at 5:41 pm
    Now available. You need to update through Bridge.
    Here is the list of fixes:
    A crash when closing the titler, or creating a new title has been fixed.
    ��l Applying a single-sided transition with no border to a video clip in the V2 track or higher, now functions correctly.
    ��l Export Audio from Source Monitor no longer results in an error message.
    ��l Rendering a Gradient Wipe transition no longer causes Premiere Pro to hang.
    ��l Conflicts between start timecode of P2 clips displayed in the project panel and the correct source start timecode have
    been resolved.
    ��l Scrubbing a clip in the source or program monitor that was imported from an external drive no longer causes an
    application hang.
    ��l QT footage captured in FCP will correctly retain the tape timecode.
    ��l Errors in MPEG files that appeared as red frames have been corrected.
    ��l Exported P2 clips that have an in point other than 00:00:00:00 and span two or more MXF files, no longer show a
    Perry Cheng replied 18 years, 9 months ago 8 Members · 15 Replies
  • 15 Replies
  • Mike Velte
    December 6, 2007 at 7:45 pm
    Thanks for the heads up! Have we ever seen a list of bug fixes for Premiere, at least this large??
  • Eric Jurgenson
    December 6, 2007 at 7:55 pm
    Is this just for Macs? I don’t see 3.1.1 on my Windows machine.
  • Mike Velte
    December 6, 2007 at 8:08 pm
    I just updated on my PC. You must use Bridge CS3…Help>Updates
    Close all apps to install.
  • Baz Leffler
    December 6, 2007 at 11:28 pm
    Congratulations Adobe and welcome to the 21st Century!
  • Thud
    December 7, 2007 at 3:10 am
    should i down load this update if i have not installed leopard?
  • Gus Franklin
    December 7, 2007 at 5:23 am
    I have been trying to install the 3.1 patch since it was made available last month. However, I kept receiving the fatal “Installation was Unsuccessful” message.
    When 3.1.1 was released today, I was hoping that the new patch would work. However, it did not. I have already tried using the Adobe Updater and the file on adobe.com. Neither way works. I have even re-installed my whole Production Premium CS3 software and that did not solve the problem.
    Does anyone have any advice? I would really like to take advantage of all the bug fixes.
    Thanks in advance.
  • Jon Barrie
    December 7, 2007 at 7:35 am
    Did you upgrade to CS3 after having CS2 software on your computer?
    You will need to run the CS3clean. Do a search on the net.
    – Jon
  • Gus Franklin
    December 7, 2007 at 2:20 pm
    Hi Jon. Thanks for responding.
    My CS3 software was installed on a new computer earlier this year. It has nothing on it, but CS3.
    All other patches install without issue.
  • Perry Cheng
    December 7, 2007 at 9:10 pm
    I am having similar problem as Gus except only on the Camera RAW and Bridge… I will try to update this patch tonight or tomorrow.
    Perry
  • Jon Barrie
    December 8, 2007 at 12:47 am
    Try using BridgeCS3 to Help> Updates… That is the Adobe recommended way to update all your stuff. You might need to go to the preferences and tick the boxes to all the updates as they may not all be coming through automatically.
    Close all CS3 Apps and Firefox. Let it do it’s thing.
    – Jon 🙂
