Activity Forums Adobe Premiere Pro Premiere Pro Update 3.1.1
  • Perry Cheng
    December 8, 2007 at 4:45 am
    My update button has been grayed out for quite sometimes under Bridge. PPro is fine. Perry
  • Jon Barrie
    December 8, 2007 at 5:02 am
    That doesn’t sound right at all. It seems your install is not quite right. Help> updates should be available.
    Have you actually used Bridge to navigate to some clips etc.
    If you haven’t used it yet that could be part of it not showing up yet?
    I’d reinstall the whole lot. A pain, but it would eliminate the possibility of a bad install.
    – Jon
    PS: If that doesn’t work contact Adobe about it. You will have to create an AdobeID if you don’t already have one.
    Click here
  • Perry Cheng
    December 8, 2007 at 5:53 pm
    Jon, First thank you. Second, I have uninstall and reinstall couple of times several months back, and it is still the same. I was able, however, successfully update to PPro 3.1.1 from PRemiere, not Bridge. Like I said, Bridge update is there, but grayed out. I am not able to click on it. I was hoping Adobe has a fix for that soon. I don’t think I am alone, people are having problem with updates since CS3.
    Perry
  • Mike Velte
    December 8, 2007 at 9:43 pm
    Perry, how many Bridges do you have…make sure you are using Bridge CS3, not 2.0.
  • Perry Cheng
    December 9, 2007 at 1:47 pm
    Yes, I only have 1 Bridge CS3, it says 3.01. I did upgrade from CS2, but, I thought I upgraded removed the old, perhaps that was not so? I thought I remembered it used to have the upgrade version until I update to 3.01, then the update has been grayed out ever since.
    Perry
Page 2 of 2
