Activity Forums Adobe Premiere Pro Premiere pro UI blurry in 4k monitor.
  • Premiere pro UI blurry in 4k monitor.
    Posted by Pedro Santos on February 11, 2019 at 8:45 pm
    Hello, guys!
    My premiere pro UI is blurry (kind of out of focus) when using a 4k monitor.
    I read somewhere that I should change the DPI settings in the properties.
    When I do that, the UI does not look burry anymore. But, everything looks really small. Panels, letters, etc
    Ill attach two screenshots for you guys to see.
    The first two are with the DPI settings at default. The other one is changing the DPI to “app”.
    https://imgur.com/a/pspG5dw
    https://imgur.com/a/pR8QiVv
    https://imgur.com/a/z60iK83
    Any help? Or this is the expected behavior?
    Also, it happens with other adobe apps such as Audition and Illustrator. But, with Photoshop and Lightroom, I have no problem at all.
    Thanks a lot already!
    View post on imgur.com
    Todd Perchert replied 7 years, 6 months ago 2 Members · 3 Replies
  • Todd Perchert
    February 11, 2019 at 9:20 pm
    Couple of things. You need to use native resolutions for that monitor, or you will get blurry images/text on that monitor. 4k on a pc monitor, at the highest resolution, will result in small text and icons. You should have additional sizes you can select that are still native resolutions, or you’ll need to change your text size. Also, your video card needs to be able to do your resolution, or you can have blurry text – this includes the cables you use to attach to your monitor from the pc.
    So, with that, what is your video card, PC, monitor, and how are you connecting it all?
    TC
  • Pedro Santos
    February 11, 2019 at 9:31 pm
    Hi! Thanks for the reply.
    So, my pc is:
    i7-7700K
    LGA 1151 mATX PRIME B250M-PLUS
    VGA ASUS Geforce GTX1060 6Gb GDDR5
    4x HyperX FURY 8GB 2133Mhz DDR4 CL14
    970 evo 512gb ssd
    My display is a LU28E590DS.
    The cable I am using came with the display and it is a displayport cable.
    My windows zoom config is set to 150%, which is the recommended. My resolution is set to 3840×2160.
  • Todd Perchert
    February 12, 2019 at 4:15 pm
    So you have the magnifier zoom level to 150%? When you change that from 100% to 150%, is that when the text goes a little blurry? Looking at your specs, everything should power that monitor just fine. But I’m wondering if your zoom setting is causing the issue. I would try finding a different resolution that works, rather than use magnifier zoom setting. Also, along with changing resolutions, try changing rate as well to see if you can find one that works with your setup.
    TC
