Activity Forums Adobe Premiere Pro Premiere Pro Slideshow
  • Premiere Pro Slideshow
    Posted by Drake Petersen on April 23, 2008 at 10:30 pm
    I just got Premiere Pro and have no idea how to use it yet but I urgently need to make a slide show for someone. I got all the pictures imported and everything and have the durations correct but I would like to make it look nicer. Is it possible to pan over still images during a video in premiere? Like a Ken Burns documentary? I looked in video effects with no luck. Also does anybody have any other suggestions on how I can make an impressive slide show?
    >>>Drake
    Vincent Martin replied 18 years, 4 months ago 3 Members · 2 Replies
  • Perry Cheng
    April 24, 2008 at 1:42 am
    Drake,
    PPro obviously can do such project but it will be very time consuming. Slide show is not its strength. However, if you insist, sure, just use the storyboard feature (in the older Premiere version, not sure if still in CS3), or simply drag the pictures into the timeline, then, rearrange it, then, add transitions, then, define each motion of each picture (If you are not picky regarding each motion, you can save motion as preset and then reload them to apply to other pictures).
    P.S.: I use MS Photostory 3 (FREE) for slide shows. They are also Flip Albums and other tools for slideshows as well.
    Perry
  • Vincent Martin
    April 24, 2008 at 4:26 am
    I did a ken burns like documentary that had tons of moving slow over pictures complete with easing in and out. This was a time consuming and meticulous process that would likely not be something you want to do for a strictly slide show video.
    How I did it was to select the picture and go into the effects window. I would set a keyframe at the beginning of the picture clip and the end. with the end keyframe selected I would move the picture in the program window to a new position. This would require premiere to render the movement of the picture from the start point to the end point. I would also change the position and zoom of the pictures in this way to slowly zoom in or out or across. This takes a long time and involves much trial and error.
    I would do what the other guy said and get a plugin or program that is designed specifically for moving pictures around in video. But if you want to take the time It can be done in premiere. There will be pronlems of flicker though I think and also some problems due to the fact the end result would be interlaced.
    Cheers
