Activity › Forums › Adobe Premiere Pro › premiere pro shows wrong background in imported AE-composition
  • premiere pro shows wrong background in imported AE-composition
    Posted by Carole Jones on November 9, 2012 at 9:21 pm
    i made a comp in after effects CS5.5 including textlayer, mov-layer, solid and shape layer. The background color of the comp is red.
    When i import the comp in premiere pro it shows a black background instead of a red one
    pretty weird, because the rendered out mov in AE actually does show the red background.
    Thanks for help
    Carole Jones replied 13 years, 10 months ago 3 Members · 4 Replies
  • Angelo Lorenzo
    November 10, 2012 at 12:11 am
    In After Effects, does the alpha channel look normal? Should be pure white. Premiere’s background color is black, so I’m wondering if it’s a transparency issue.
    Angelo Lorenzo
    Love my answer? Do me a huge favor and check out my Kickstarter project The Librarian, starring Jennie Garth of Beverly Hills 90210.
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Carole Jones
    November 10, 2012 at 8:50 am
    Hi there,
    I created a solid layer, put it underneath my “dancing girl -mov” in the layer hierarchy
    And switched under “none” to “Alpha Matte”, but the red color stems from composition settings…
    Ts ts… ? Thanx 4 response!
  • Alex Udell
    November 10, 2012 at 1:49 pm
    Hiya…
    Composition space in AE is empty even if it is set to show as “red” instead of the default black.
    PPro sees it as fully transparent.
    So either add a solid as the base of you AE comp.
    Or add a Color matte on v1 in PPro and place the AE comps on V2…
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Carole Jones
    November 10, 2012 at 6:50 pm
    Hi Alex,
    thanks ever so much for your help, first version with putting a Red Solid layer underneath comp worked perfectly ! Saved my evening;-)
    carole
