Activity › Forums › Adobe Premiere Pro › Premiere pro problem.How to reduce the number of audio channels in export settings
  • Premiere pro problem.How to reduce the number of audio channels in export settings
    Posted by Andrew Marchand on October 14, 2006 at 2:42 am
    I am getting an error message when I try to export a sequence “the number of audio channels to create in the exported file must be equal to or less than the number of channels in the source” aswell as “please reduce the number of audio channels in export settings”. I cant seem to do it. Anybody know?
    Harm Millaard replied 19 years, 11 months ago 3 Members · 4 Replies
  • Steven L. gotz
    October 14, 2006 at 2:46 pm
    If you have a stereo master track, you can not export a 5.1 clip. Is that the issue?
    Steven
    https://www.stevengotz.com
  • Andrew Marchand
    October 15, 2006 at 1:07 am
    I dont know what a stereo master track is.Could you possibly explain. The audio export settings are: uncompressed, sample rate is 44100 Hz, sample type is 16-bit, no channels (and it wont let you add any more), interleave is 1/2 second.Thanks.
  • Steven L. gotz
    October 15, 2006 at 3:13 am
    Your sequence has a master track for the audio. Look at the bottom of the timeline and determine how you set up your sequence.
    And then tell us what you are exporting to.
    Steven
  • Harm Millaard
    October 16, 2006 at 11:50 am
    Why 44.1 KHz instead of 48 KHz?
    Harm Millaard
