Activity Forums Adobe Premiere Pro Premiere Pro not outputting 1920 x 1080 p (25 fps) to external monitor
  • Premiere Pro not outputting 1920 x 1080 p (25 fps) to external monitor
    Posted by Adam Read on February 23, 2017 at 4:41 pm
    Hi
    For some bizarre reason, my Intensity Shuttle is not outputting 1920 x 1080p (25fps) to the external monitor when using ANY of the Adobe sequence presets.
    It is only outputting if I select 1080i 25fps (which to my knowledge means interlaced, which the file/sequence is not.
    Can anyone shed any light on this?
    I contacted Blackmagic and they said contact Adobe. I contacted Adobe, and guess what? – they said contact Blackmagic!
    Thanks in advance
    ADAM READ
    Peter Garaway replied 9 years, 6 months ago 3 Members · 2 Replies
  • Andy Patterson
    February 23, 2017 at 5:00 pm
    [Adam Read] “For some bizarre reason, my Intensity Shuttle is not outputting 1920 x 1080p (25fps) to the external monitor when using ANY of the Adobe sequence presets.
    I contacted Blackmagic and they said contact Adobe. I contacted Adobe, and guess what? – they said contact Blackmagic!”
    The intensity Shuttle will only output Broadcast compliant aspect ratios, resolutions and frame rates. 25P should work. Have you tried downloading a different driver?
  • Peter Garaway
    February 24, 2017 at 12:29 am
    Hi Adam,
    A few things you can try that may help:
    1. Trashing your Premiere Pro preferences.
    2. Open the Blackmagic Desktop Utility app. Verify your output settings match Premiere.
    3. Should not be required but you may try changing some of the output options inside the BMD set panel. To do this go to Preferences > Playback > Click the ‘setup’ button next to ‘Blackmagic playback’. Try modifying the settings in there to see if you have any luck.
    Let us know how it goes.
    Peter Garaway
    Adobe
    Premiere Pro
