Activity Forums Blackmagic Design Premiere Pro not outputting 1920 x 1080 p (25 fps) to external monitor with BM Intensity Shuttle
  • Premiere Pro not outputting 1920 x 1080 p (25 fps) to external monitor with BM Intensity Shuttle
    Posted by Adam Read on February 23, 2017 at 4:41 pm
    Hi
    For some bizarre reason, my Intensity Shuttle is not outputting 1920 x 1080p (25fps) to the external monitor when using ANY of the Adobe sequence presets.
    It is only outputting if I select 1080i 25fps (which to my knowledge means interlaced, which the file/sequence is not.
    Can anyone shed any light on this?
    I contacted Blackmagic and they said contact Adobe. I contacted Adobe, and guess what? – they said contact Blackmagic!
    Thanks in advance
    ADAM READ
    Shane Ross replied 9 years, 6 months ago 2 Members · 1 Reply
  • Shane Ross
    February 28, 2017 at 3:10 am
    Your monitor might not be capable of 25p…only of receiving a 25i signal. 25i is fine… and while the SIGNAL getting to the monitor is interlaced, the footage will still be progressive.
    Shane
    Little Frog Post
