Activity Forums Adobe Premiere Pro premiere pro mac crashing
  • premiere pro mac crashing
    Posted by Andrew Silk on December 3, 2009 at 1:28 am
    Hi, Premiere Pro 4.2 is crashing semi regularly when I’m trying to play back video that has a title. It does it with different fonts, not just one. I’ve tried removing fonts, I’ve tried having premiere make a new project with the footage from the project manager, i’ve tried restarting, i’ve tried it on a fresh install (which I was planning to do anyway) of 10.6.2 with 4.2, (and no extra fonts added other than what apple and what Adobe installed)
    both setups have final cut as well installed, but not running. I’ve also seen in the activity monitor (on the original 10.5.8 setup) that the photoshopserver isnt responding) Any ideas here? please help!
    Exception Type: EXC_BAD_ACCESS (SIGBUS)
    Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
    Crashed Thread: 27
    thread 27 first, then the rest..
    Thread 27 Crashed:
    0 …miere.TitleCharacterFactory 0x0a016f60 UnZipAllData(unsigned char*) + 152
    1 …miere.TitleCharacterFactory 0x0a0193b5 CPlans::UnzipMasks(std::list >) + 323
    2 …miere.TitleCharacterFactory 0x0a011215 CPlans::PaintFaces(std::list
    >) + 47
    3 …miere.TitleCharacterFactory 0x0a012b03 CPlans::Paint() + 823
    4 …miere.TitleCharacterFactory 0x09fd7c59 DeleteSurface + 73
    5 com.adobe.premiere.TitleCG 0x0a1300fd RenderManager::Flush() + 51
    6 com.adobe.premiere.TitleCG 0x0a1719f1 refreshLayer(RenderManager&, std::vector > const&, LAYOUT_REC const*, ObjLayer const&, FRECT const&, unsigned long) + 315
    7 com.adobe.premiere.TitleCG 0x0a172dd0 refreshRect(Inscriber::StubLayer*, LAYOUT_REC const*, FRECT const*, FRECT const*, unsigned long) + 1606
    8 com.adobe.premiere.TitleCG 0x0a1086f4 cgiRefreshRect + 100
    9 com.adobe.premiere.TitleLayout 0x0a791ca3 Inscriber::Implementation::LayoutRecRenderer::RenderStillImage(Inscriber::Layout*, Inscriber::Image*) + 205
    10 …dobe.premiere.TitleRenderer 0x0b63d284 CG::TitleImplementation::Render(int, int, int, int, int, int, void*, unsigned long, void const*)::RenderAction::RenderToImage(Inscriber::Image*) + 296
    11 …dobe.premiere.TitleRenderer 0x0b646000 CG::TitleImplementation::Render(int, int, int, int, int, int, void*, unsigned long, void const*) + 1192
    12 …dobe.premiere.TitleRenderer 0x0b4ef743 TitlerML::(anonymous namespace)::RenderTitle(ASL::InterfaceRef, CG::Title*, int, int, int, MF::BinaryData const*) + 3841
    13 …dobe.premiere.TitleRenderer 0x0b4f0797 TitlerML::TitlerSource::GetVideo(ASL::Time const&, MF::BinaryData const&, ASL::Time const&, ASL::Time const&, ASL::InterfaceRef, long, bool, bool, bool, bool, double) + 695
    14 …re.Frameworks.VideoRenderer 0x04376692 ML::RenderFrameRequest::GetSourceVideo(ASL::ParamRect, MF::PixelFormat, ASL::InterfaceRef, ASL::Time, MF::BinaryData, ASL::Time, ASL::Time, long, bool, unsigned long, ASL::ParamColor const&, bool, bool, bool, double, MF::FieldType, bool, ASL::InterfaceRef&) + 700
    15 …re.Frameworks.VideoRenderer 0x04379424 ML::RenderFrameRequest::RenderInterpolatedFrame(ASL::ObjectPtr, ASL::ParamRect, MF::PixelFormat, ASL::InterfaceRef, ASL::Time const&, ASL::Time const&, ASL::Time const&, double, long, ASL::InterfaceRef&) + 4560
    16 …re.Frameworks.VideoRenderer 0x0437f572 ML::RenderFrameRequest::RenderImportedVideoSegmentNode(ASL::ObjectPtr, ML::RenderFrameRequest::RenderState, MF::PixelFormat, ML::RenderFrameRequest::MediaInfo&) + 3096
    17 …re.Frameworks.VideoRenderer 0x0434c3fd ML::MediaNodeProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 3917
    18 …re.Frameworks.VideoRenderer 0x04340425 ML::CompositorProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 787
    19 …re.Frameworks.VideoRenderer 0x0432a9fc ML::ProduceFrame(ASL::InterfaceRef const&, ML::CutlistRenderParams const&, MF::FrameTime const&, std::vector > const&, bool) + 192
    20 …re.Frameworks.VideoRenderer 0x04380e21 ML::RenderFrameRequest::Render(MF::PixelFormat) + 627
    21 …re.Frameworks.VideoRenderer 0x04368352 ML::RenderFrameQueue::Render(ML::RenderFrameRequest&) + 382
    22 …re.Frameworks.VideoRenderer 0x0437e242 ML::RenderFrameRequest::RenderImportedVideoSubTree(ASL::InterfaceRef, ASL::ObjectPtr, ASL::Time const&, ASL::Time const&, ASL::Time const&, ASL::ParamRect const&, MF::PixelFormat, double, ASL::FrameRate const&, bool, bool) + 2456
    23 …re.Frameworks.VideoRenderer 0x0437f274 ML::RenderFrameRequest::RenderImportedVideoSegmentNode(ASL::ObjectPtr, ML::RenderFrameRequest::RenderState, MF::PixelFormat, ML::RenderFrameRequest::MediaInfo&) + 2330
    24 …re.Frameworks.VideoRenderer 0x0434c3fd ML::MediaNodeProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 3917
    25 …re.Frameworks.VideoRenderer 0x0433acad ML::ClipNodeProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 1095
    26 …re.Frameworks.VideoRenderer 0x04340425 ML::CompositorProducer::ProduceFrame(MF::FrameTime const&, ML::CutlistRenderParams const&, ASL::InterfaceRef&) const + 787
    27 …re.Frameworks.VideoRenderer 0x0432a9fc ML::ProduceFrame(ASL::InterfaceRef const&, ML::CutlistRenderParams const&, MF::FrameTime const&, std::vector > const&, bool) + 192
    28 …re.Frameworks.VideoRenderer 0x04380e21 ML::RenderFrameRequest::Render(MF::PixelFormat) + 627
    29 …re.Frameworks.VideoRenderer 0x04368352 ML::RenderFrameQueue::Render(ML::RenderFrameRequest&) + 382
    30 …re.Frameworks.VideoRenderer 0x043688c2 ML::RenderFrameQueue::ServiceQueue(bool) + 594
    31 …re.Frameworks.VideoRenderer 0x04368eef ML::RenderFrameQueueWorker::Process() + 77
    32 …e.Frameworks.ASL.Foundation 0x01a4b815 boost::detail::function::void_function_obj_invoker0, boost::_bi::list1 > > >, void>::invoke(boost::detail::function::function_buffer&) + 55
    33 dvacore 0x004d3658 boost::detail::function::void_function_obj_invoker0 >, void>::invoke(boost::detail::function::function_buffer&) + 36
    34 dvacore 0x004dd1d3 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr const&, dvacore::threads::ThreadPriority, boost::shared_ptr const&) + 335
    35 dvacore 0x004d8395 boost::detail::function::void_function_obj_invoker0 const&, dvacore::threads::ThreadPriority, boost::shared_ptr const&), boost::_bi::list3 >, boost::_bi::value, boost::_bi::value > > >, void>::invoke(boost::detail::function::function_buffer&) + 33
    36 dvacore 0x004d3658 boost::detail::function::void_function_obj_invoker0 >, void>::invoke(boost::detail::function::function_buffer&) + 36
    37 dvacore 0x004dd082 dvacore::threads::(anonymous namespace)::ThreadGroup::LaunchThread(std::basic_string, std::allocator > const&, boost::function0 > const&) + 26
    38 dvacore 0x004da3cd boost::detail::function::void_function_obj_invoker0, std::allocator
    > const&, boost::function0 > const&), boost::_bi::list2, std::allocator > >, boost::_bi::value > > > >, void>::invoke(boost::detail::function::function_buffer&) + 177
    39 dvacore 0x004d0182 boost::function0 >::operator()() const + 34
    40 dvacore 0x00449683 thread_proxy + 99
    41 libSystem.B.dylib 0x90035155 _pthread_start + 321
    42 libSystem.B.dylib 0x90035012 thread_start + 34
    Andrew Silk
    Visual Storyteller
    Andrew Silk replied 16 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
