Activity › Forums › Adobe Premiere Pro › Premiere pro / intensity pro / Sony fx1000 HDMI capture issue
  • Premiere pro / intensity pro / Sony fx1000 HDMI capture issue
    Posted by Dave Turner on August 27, 2009 at 11:05 am
    Hi all,
    I have a sony fx1000 and an intensity pro HDMI capture card (v.3.2 driver)and am using premiere pro (v. 4.1). When I try to capture inside premiere either from the camera in record mode or playback off of a DV tape I merely get a black screen.
    I am recording in 1080i and have tried it with 24p and just 1080i.
    I have an HDMI cable running from the camera to the intensity pro card (and it is in the input and not the output) I have premiere using the blackmagic settings when nim setting up a project.
    I wonder if someone could help me with the config.
    Dave
    Dave
    Brian Louis replied 17 years, 1 month ago 2 Members · 1 Reply
  • Brian Louis
    August 27, 2009 at 6:21 pm
    The capture window in Ppro will be black when capturing HDV, if you want to monitor, connect the output of the IntensityPro to a HD monitor to view the capture.
