Activity › Forums › Adobe Premiere Pro › Premiere pro hardware upgrade
  • Premiere pro hardware upgrade
    Posted by Dominik Sulser on December 24, 2015 at 11:48 pm
    dear forum
    i want to upgrade my hardware my goal is to make to waiting times shorter for rendering, stabilizing etc.
    i actually don’t know which part should be upgraded and which parts i can still let on the Board.
    my setup is:
    Board: Gigabyte 990FXA-UD3
    CPU: AMD FX-8320 8-core 4.23 GHz
    Ram: 12GB
    GPU: nvidia geforce gtx 970 4GB
    SSD and HDD does it matter?
    need more informatin? please ask!
    thank you for support!
    Dominik
    Ivan Myles replied 10 years, 9 months ago 2 Members · 1 Reply
  • Ivan Myles
    December 26, 2015 at 2:24 am
    Hardware constraints will vary at different stages of the process. Have you tried using any system tools to monitor performance during the render/encode process? In general, SSD(s) would be a high priority. RAID with high speed I/O might be required depending on your usage scenario. Additional RAM is a low cost upgrade. Also consider things like a UPS and disk backup system which won’t necessarily boost performance, but might save time if something goes wrong.
