Activity Forums Adobe Premiere Pro Premiere Pro Export Problem
  • Premiere Pro Export Problem
    Posted by Jimmy Doyle on April 13, 2011 at 5:49 am
    I have Premiere Pro CS5 on a PC. I have downloaded all available updates. Fast computer, lots of ram, etc.
    I have a project that has 30 seconds of an intro which was titles made in After Effects, then 7 minutes of P2 footage from an HPX 170 then 30 seconds of credits made in After Effects. I have to export this to Quicktime with DVCPRO HD 720 Codec.
    When I export, everything is okay until it gets to the end credits, then it stops. It does not crash, the bar quits moving and the time remaining starts going up. I don’t know what to do because it exports the intro which I exported from After Effects exactly the way I did the end credits. I have tried exporting the credits from After Effects as Quicktime, AVI, JPEG sequence, TIFF sequence and h264 and it stops at the same place every time. I have moved the credits ten seconds later in the timeline and it still hangs up at the start of the credits.
    Any ideas?
    Jimmy Doyle replied 15 years, 5 months ago 2 Members · 2 Replies
  • Tim Kolb
    April 13, 2011 at 2:56 pm
    Will it export if you simply remove the end credits (as a test)?
    Then…will a timeline with just the end credits export?
    If no/yes, I’d look at the end of the 7 minute section instead of the credit clip.
    If yes/yes, I’d consider what I’m using for a transition between the last P2 clip and the credits…maybe try forcing “Render Entire Sequence” then see if Media Encoder will get through it all. Perhaps there is a transition the Media encoder chokes on…there aren’t many, but I’ve discovered a few.
    TimK,
    Director, Consultant
    Kolb Productions,
  • Jimmy Doyle
    April 13, 2011 at 5:51 pm
    Well it wasn’t the transition but that helped me find out what it was. There were no transitions, just taking opacity to zero. When I tried to put a transition on it I found that there was a frame in between the last clip and the credits. I moved the credits next to the last clip and it rendered fine. I can’t believe it was as simple as that.
    Thanks so much for your help.
