Activity Forums Adobe Premiere Pro Premiere Pro effects render order
  • Premiere Pro effects render order
    Posted by Jim Bachalo on June 19, 2011 at 4:19 pm
    Hi
    Trying to set up a common workflow between After Effects and Premiere so that a common custom s Curve or LUT is ALWAYS applied last in the render chain, whether I am rendering out from PPRo or AE.
    My understanding of the render order in AE is simply within a composition, from bottom to top, and within each layer, from top to bottom.
    So if rendering from AE I would simply use an adjustment top layer with my s Curve-LUT applied.
    And if rendering from PPro, (equating sequences to compositions and tracks to layers), I would use a nested sequence and apply this same s Curve-LUT as my BOTTOM most effect to the nested sequence.
    Am I correct in my logic?
    Local is the new global
    Todd Kopriva replied 15 years, 2 months ago 2 Members · 1 Reply
  • Todd Kopriva
    June 19, 2011 at 7:05 pm
    I think that you have it right.
    BTW, your summary of the render order in After Effects (though correct for this case) is a bit oversimplified. In case you care about the details, they’re here.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
