Activity Forums Adobe Premiere Pro Premiere Pro Dropping Frames skipping on playback and timeline
  • Premiere Pro Dropping Frames skipping on playback and timeline
    Posted by Chris Hill on October 16, 2021 at 4:10 am
    Hey all! Coming for help as I have tried everything (did the good ole google search):
    deleted cache
    rebooted
    moved cache folder
    rendered part of my timeline
    setup for CUDA rendering
    then went back to software as it didn’t help
    I uninstalled the program and even tried to install an older version, still didn’t work
    turned off high quality playback
    set playback resolution to 1/2
    I also opened an old project that I knew worked well and now its glitching as well. so I have no idea what to do. Check the video attached at :35 seconds, and 3:03 to see it glipping, I am at wits end
    https://drive.google.com/file/d/1EnP0mPl5dEMGJBpUcm9uD_eeW6I5IIzr/view?usp=sharing
    Tero Ahlfors replied 4 years, 10 months ago 3 Members · 2 Replies
  • Todd Perchert
    October 19, 2021 at 7:14 pm
    Best guess is that the footage was really a variable frame rate, but who knows…. I would try using something like Handbrake to transcode to a constant frame rate and see if that works.
    TC
  • Tero Ahlfors
    October 21, 2021 at 3:55 pm
    This is probably the weird bug that you’ll need pick none for your audio input device because there might be some default audio device there after some update.
