Activity Forums Adobe Premiere Pro Premiere Pro CS6
  • Premiere Pro CS6
    Posted by Victoria Guzik on June 18, 2014 at 5:53 pm
    I have just finished setting up my editing system with Premiere Pro CS6. It is a turnkey system from Safe Harbour. Will I be able to edit projects previously saved from Premiere Pro 1.5 and 2.0?
    Thanks.
    Victoria
    Victoria Guzik replied 12 years, 3 months ago 2 Members · 2 Replies
  • Tim Kolb
    June 18, 2014 at 6:56 pm
    CS3 or CS4 should be pretty seamless, but that’s quite a leap, and I haven’t tried to load projects over that large a span recently, but typically Premiere Pro has been pretty backward compatible.
    I would say that there have been enough structural changes that you may see some gaps…but you won’t harm the projects by trying it
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
  • Victoria Guzik
    June 18, 2014 at 8:09 pm
    Thanks. Basically what I was hoping is that once I get it into the timeline I could do some small edits and add chapter and then be able to burn the disc in Encore. I still have a computer with the old system and I used DVD Workshop in that one. Don’t want to go back to that, and I want to use some old projects to learn the system.
