Activity Forums Adobe Premiere Pro Premiere Pro CS6 Preview really slow and laggy ?
  • Premiere Pro CS6 Preview really slow and laggy ?
    Posted by Harvey Brepson on March 15, 2013 at 8:53 pm
    when I’m using Premiere and I want to preview my video (even at 1/4 of a quality !),
    it is really slow and REALLY laggy ! Even on 720p footage !
    I’ve made a change in “cuda_supported_cards” in C:\Program Files\Adobe\Adobe Premiere Pro CS6 so that it could support my card, and it does, but no changes…
    I run on a Asus G75V,
    Intel i7 2.3Ghz, 16gb or RAM, and Nvidia GeForce GTX 670M 3gb.
    I should add that it is 720p 60p footage from a hacked GH2,
    I don’t know if it helps.
    Thank you for your time.
    Mohamed Magdy replied 11 years, 6 months ago 6 Members · 5 Replies
  • Edward Montezinos
    March 15, 2013 at 9:25 pm
    Same here,
    Got a quad core I7, 12 GB of RAM, an NVidia Geforce GTX 660M 2GB
    A short (20 sec) 1080P 50 fps vid is laggy!!!
  • Stu Siegal
    March 16, 2013 at 9:14 pm
    Well, there are lots of things it could be, one of which is CS6’s cache buffering issue. Below is a link to a thread on the Adobe forums, disappointing that no one from Adobe has officially acknowledged it. If you think this is your problem, I’d strongly suggest using the bug report link, and maybe we’ll get some response.
    https://forums.adobe.com/thread/1146108
    Bug link:
    https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
    http://www.stusiegal.com
  • Eugene
    April 11, 2014 at 5:19 pm
    For me, it was the use of warp stabilizer on a clip, even though it was disabled in the effects menu. I just deleted the clip from the timeline and brought in the same raw/fresh clip from the project window into the timeline again. That worked for me. I guess i could have deleted the warp stabilizer from the clip, but i just deleted the whole thing and brought the clip in again. I’ll just reapply the warp stabilizer after i edited the clip.
  • Jeff Smith
    July 16, 2014 at 12:12 am
    any other suggestions? i’m not using warp speed but its very laggy to play. 2 or 3 seconds
  • Mohamed Magdy
    February 28, 2015 at 5:09 am
    I used to get stuck with this problem. I finally solved it by changing the “video playback settings” from “the sequence settings” in the “sequence” menu. The default resolution is 1920 x 1080. I changed it to 640 x 360, and after that playback was always 100% smooth, even while using a mixture of .mts and .mvi full HD files, with contrast and brightness effects on them, without even having to render at all, even while the bar is red.
