Activity Forums Adobe Premiere Pro Premiere Pro CS6 and Sonicfire plugin
  • Premiere Pro CS6 and Sonicfire plugin
    Posted by Victoria Guzik on January 31, 2015 at 3:16 pm
    Recently purchased the Sonicfire plugin from Smart Sound. I’m not clear how to set up the settings so that the plugin works the way it should. Sending a tract to Premiere seems to be okay, but each time I click on it to do some editing of the track it shows above the track an “untitled” and when I send it to Premiere it puts it in a temp file. Is this the way it’s supposed to work and what do I do with all those untitled temp files? Thanks.
    Victoria
    Victoria Guzik replied 11 years, 7 months ago 2 Members · 2 Replies
  • Ann Bens
    January 31, 2015 at 10:16 pm
    Maybe this will help, have not seen the video myself.
    https://www.video2brain.com/en/lessons/premiere-pro-and-after-effects-cs6-smartsound-plug-ins
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Victoria Guzik
    January 31, 2015 at 10:53 pm
    Thank you for your response. I have watched Jeff Foster’s youtube video several times and although I follow his tutorial, I do not get the same result. I wonder if the fact that I also have Matrox whether that makes a difference. On his video I do not see the “untitled” that shows on mine. Thanks.
