Activity Forums Adobe Premiere Pro Premiere Pro CS6 and pictures
  • Premiere Pro CS6 and pictures
    Posted by Victoria Guzik on August 16, 2014 at 12:55 pm
    I am editing a wedding video in Premiere Pro CS6 and I would like to add some pictures to the beginning of the timeline that I downloaded from facebook. What do I need to do to make them compatible and look good on the DVD? I may also be adding some movement. Thank you.
    Victoria
    Victoria Guzik replied 12 years, 1 month ago 2 Members · 3 Replies
  • Kevin Monahan
    August 18, 2014 at 10:52 pm
    Hi Victoria,
    I’m sure the images coming from Facebook will be fine as is. Report back to us any trouble you have.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Victoria Guzik
    August 19, 2014 at 9:36 pm
    Thanks. In previous versions of Premiere Pro to put still images in the timeline I had to make sure that they were 720 x 480. Does that not matter now in the newer version? Also, if I remember correctly the resolution in video is 72, but if I wanted to zoom in I had to have a higher resolution. I plan on doing some editing in Photoshop so I’m wondering what settings I should use to save the photographs. None of the tutorials that I purchased address this.
    Thanks.
  • Victoria Guzik
    August 21, 2014 at 2:07 am
    Sorry I sent the previous post to your reply. Decided to open the program and see what I could do. Entering the pictures is not as complicated as I thought Figured it out without too much trouble.Have the intro done to the video. Have to work on motion now. Thanks for your help.
