Activity Forums Adobe Premiere Pro Premiere Pro CS5.5 Red Screen Glitch With MOV Files
  • Premiere Pro CS5.5 Red Screen Glitch With MOV Files
    Posted by Matthew Castro on July 24, 2011 at 7:29 pm
    Hey Editors On The Cow!
    I’m having trouble and was wondering if you guys can help me out.
    I have some files from Final Cut Pro’s h.264 MOV files, and some .MP4 files from a client that wants me to place the two together and give them a master MOV file.
    So I’m using Premiere Pro to place them both onto the timeline for export, but the MOV files are giving me a red pixelation error, and I cannot understand why it’s happening.
    Here is what it looks like 2665_error.jpg.zip
    I’ve tried using different sequence settings, and even used a matched setting, but all it does is just moves the red screen around to a different spot.
    I’ll try re-exporting the original file again to see if it solves anything, but this has happened multiple times. Does anyone know a solution or is there something that I’m just overlooking?
    This is probably just a program error, so I don’t think my comp specs will help, but here it is anyway:
    Mac Pro running Mac OS X
    2×3 GHz Quad-Core Intel Zeon
    20GB 800 MHz DDR2
    And of course, program and files are on separate hard drives, etc.
    Matthew Castro replied 15 years, 1 month ago 2 Members · 2 Replies
  • Jon Barrie
    July 25, 2011 at 3:13 am
    Have you tried to clean the cache from the Preferences? Then allow the indexing, conforming etc to finish before working? It looks like a dropped frame from HDV capture. usually a recapture of that section will correct this, but it sounds like you are working with a file that already exists. This could be problematic.
    What is your process here…?
    Is it appearing after you render out or in the original media?
    – JB
    Jon Barrie
    aJBprods
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
  • Matthew Castro
    July 25, 2011 at 5:57 pm
    The footage is from a Sony XDCAM EX, so it’s not captured from tape.
    It’s an already exported piece of footage that they want me to combine with another piece of footage. And when I drop the two videos onto the timeline, I scrub through the media and find these red pixelations.
    I’ve already tried placing the footage they gave me into Final Cut Pro, and exporting another copy, but I still get the same problem, only the red pixelation shows up at another time frame.
    This should be incredibly easy…but this glitch is making it extremely difficult.
