premiere pro cs5.5, proxies and AE Linked Comps
Hi everybody, I have to edit a HD music video in PPro CS5.5 and do some effects on AE. I will use low-res proxy files in Premiere Pro so the editing will be smoother, and at the end I will replace them with the original files from my 5Dmk2.
The question is: if in some scenes I’ll use the Dynamic Link (replace with after effects composition) starting from the low-res proxy, when I’ll replace them with the original files, will the “AE Linked Comps” also switch to high quality? or will they maintain the low quality of the low-res proxies that I first sent to AE?Sorry for my bad english, I hope you can help me! thank you!
