Activity Forums Adobe Premiere Pro Premiere Pro CS5.5 Audio Clicking
  • Premiere Pro CS5.5 Audio Clicking
    Posted by Alex Tushingham on June 14, 2012 at 5:43 pm
    Hey,
    So I am cutting some footage shot with a Canon 60D, and in between some of the cuts, the audio makes a clicking sound during playback, when passing over the cuts.
    It’s still faintly there after exporting but not while scrubbing the video, only when playing.
    Has anyone ever seen this before?
    I’m running a Mac Pro with 10.6.7
    2×2.66 GHz Dual-Core Intel Xenon
    6GB 667 MHz DDR2 FB-DIMM
    Angelo Lorenzo replied 14 years, 2 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    June 18, 2012 at 6:42 am
    If it’s what I think it is, it’s par for the course when it comes to editing audio. When you make a cut and join two pieces of audio, their waveforms usually don’t match up; the jump in amplitude or frequency causes that click.
    The only perfect way to cut audio is to cut on the exact sample where each waveform passes the zero mark in the waveform, not the crest or trough. This is overkill, and entirely too time consuming unless you’re creating audio loops or high end studio mixes.
    The more practical thing to do is to finish off the mix with a little two frame crossfade on each clip. Clears the problem right up.
    Angelo Lorenzo
    Fallen Empire – Digital Production Services
