Activity › Forums › Adobe Premiere Pro › Premiere Pro CS5: Viewing bug
  • Premiere Pro CS5: Viewing bug
    Posted by Cerutti Nicolas on May 16, 2010 at 4:42 am
    Hello everybody,
    Let me explain you my issue. I’ve just installed my production premium suite CS 5 and began to work with Premiere Pro. No problem to create the project and capture the video. But when I put a video in the timetable, some strange lines appears in the preview screen:
    https://www.sakatland.com/Autres/AdobeCS5-bug.png
    I noticed that if I export a frame directly from Premiere these strange lines disappears. Same if I resize or if I change the position of the file (361×288 instead of 360×288).
    I just updated my graphic card (Nvidia GTX 275) drivers but nothing changed. MY OS is Windows 7 ultimate 64 bits.
    Thanks in advance!
    Sakat
    Jan Janowski replied 16 years, 3 months ago 6 Members · 12 Replies
  • 12 Replies
  • Ann Bens
    May 16, 2010 at 9:25 pm
    Read about this before, i will see what i can do.
  • Jan Janowski
    May 16, 2010 at 10:21 pm
    Try this…. I’m guessing that these lines only show up AFTER RENDERING, right? If so, turn on Display Both Fields, and tell me if that helps…..
    Jan
    Looking for 1939 Indian Motocycle
  • Cerutti Nicolas
    May 16, 2010 at 10:39 pm
    Actually when I apply any change in the image (size, position, effects) everything is fine. The problem appears when I just move the video in the timetable. I also tried to just upper field and both fields but that didn’t change anything.
    When I do the rendering in .avi or something else there the video is clear (like the source or the preview screen when I captured).
    Strange because I had tried the demo of CS4 on the same configuration which worked.
  • Andy Prada
    May 17, 2010 at 7:50 am
    I’ve stopped using CS5 but for other reasons apropos my recent problems with Boris Graffiti (in another thread)
    I got the same initial problem as yourself but fixed by showing both fields. More worryingly however, using my 1080p monitor as an HDMI output I get very fine, almost imperceptible vertical lining on all my output (never had this on CS4, another reason for my reversion back)
  • Cerutti Nicolas
    May 17, 2010 at 9:25 am
    Ah I forgot to precise that I shoot with a Canon XL2 (PAL) at 50i.
    I checked again with the upper and lower field and find another way to show the video clearly. I go to:
    Clip -> Modifiy -> Interpret Footage
    And I change the field order from “lower field first” to “upper field first”
    But when I checked about the problem on Google I found that video shooted on MiniDV should be set on “Lower field first” no?
  • Brian Louis
    May 17, 2010 at 11:31 pm
    [Cerutti Nicolas] “MiniDV should be set on “Lower field first” no?”
    Yes
    [Cerutti Nicolas] “I shoot with a Canon XL2 (PAL) at 50i.”
    Why are you quoting these settings in your OP, Pal = 720×576
    “Same if I resize or if I change the position of the file (361×288 instead of 360×288)”.
  • Cerutti Nicolas
    May 18, 2010 at 4:24 am
    If I resize the video like 101%, 150%, 200%, … in the timetable the strange color bands disappear. It’s the same if I change the position of the video (centered in 360×288) to 361×288 or 500×300…
  • Ann Bens
    May 18, 2010 at 9:23 am
    If you have a NVidia videocard change the 3D settings to “Let the 3D application decide”.
  • Brian Louis
    May 18, 2010 at 10:37 am
    If you try what Ann says and it doesn’t work, try rolling back the driver to a older one, you could also goto the nvidia website and use the widget to tell you the optimum driver
  • Cerutti Nicolas
    May 18, 2010 at 12:23 pm
    Thank you Ann Bens! It worked!
