Activity › Forums › Adobe Premiere Pro › Premiere Pro CS5 and Kia Pro
Posted by Alvin Lowery on August 22, 2013 at 2:59 amCan Premiere Pro CS5 on on PC import and edit Pro Res files from a Kia Pro?
Alvin Lowery replied 13 years ago 2 Members · 2 Replies -
Jeff Pulera
August 22, 2013 at 2:29 pmHi Alvin,
As long as the standard QuickTime is installed on a PC, it can play ProRes files. However, I believe there’s a bug in CS5 that was fixed in later versions – it may not recognize ProRes clips with 4-channel audio, but 2-channel clips should work fine. I believe this issue was fixed on CS5.5 with a bug patch and I know CS6 works fine. I had the 4-channel audio issue when using ProRes clips from Atomos Ninja recorder.
Jeff Pulera
Safe Harbor Computers
