Activity Forums Adobe Premiere Pro Premiere Pro CS4 video output quality issues
  • Premiere Pro CS4 video output quality issues
    Posted by Ryan Jackson on January 25, 2010 at 7:21 am
    I am trying to make some changes to a DV format file, and output as the same DV format. When the video is brought into Premiere, it looks crisp in the left-hand video box. But, when playing it on the right window and when encoding it, it comes out as a mess with substantial compression artifacts.
    What confuses me is, I have experimented with a lot of codecs–even uncompressed AVI. There is no change in the video resolution–source is 720×480, as is output. I am keeping all the pixel aspect ratios the same as the source footage.
    What is creating this distortion? I have no scaling of the video whatsoever in the sequence…
    Is there some compression box I’m not seeing here?
    Peter Heald replied 16 years, 6 months ago 3 Members · 3 Replies
  • Scott Roberts
    January 27, 2010 at 7:21 am
    Are you viewing the DV file you output in Windows Media Player? I’ve noticed, on some computers, that DV videos played in WMP appear pixelated.
    https://www.myr3d.com
  • Ryan Jackson
    January 27, 2010 at 10:25 am
    Yes, I’m looking at the output in WMP and VLC… Each appears very poor.
    It doesn’t even matter which codec I use, even when I output as an uncompressed AVI, it looks horrible. Totally compressed and distorted, and blurred.
    I still think the project properties are correct. But I haven’t applied all the hotfixes from Adobe to address AVI issues… I am wondering if these hotfixes could fix the issue. I will attempt to install these when I am back home.
    In the meantime, if anyone has any other ideas, I’m open to all suggestions!
  • Peter Heald
    March 8, 2010 at 5:46 pm
    Did you find a solution to this? I’m having the exact same problem. I have found several other posts from people with similar issues, but there seems to be very little in the way of solutions.
