Activity Forums Adobe Premiere Pro Premiere pro cs3 external recorded sound out of sync
  • Premiere pro cs3 external recorded sound out of sync
    Posted by Henry Johnson on February 25, 2009 at 6:47 pm
    I have recorded an hour long video uses a sony hdd handycam and used an ipod as a portable digital audio recorder. Both the sound and the footage turned out great.
    I imported both file types into Adobe premiere pro cs3 (the footage as .mpg and the sound as .wav. The file types are native to the recorders.
    The file setup in premiere is : DV NTSC
    29.97
    720×480 4:3
    D1/DV NTSC .9
    Lower field first
    30fps drop frame timecode
    audio:
    32000 hz
    audio samples.
    The files are:
    720×480
    29.97 fps
    1.1mb /second
    Audio:
    44100 hz 16 stereo
    project audio format 32000hz 32 bit floating point stereo
    data rate 172 KB second
    Now when I sync up the sound and video from the beginning in Premiere I find that by the end of the video – the sounds drifts by about 2 seconds behind. I did some digging and couldn’t find an answer so I simply chopped up the 1 hour sound file into 10 minute sections and trimmed about 4 frames off per 10 seconds and the sound and video synced beautifully.
    But when I exported as an AVI, an MPEG2 (and many different settings of the two) I can NEVER get the sound to sync. I have tried increasing the minimum bitrate on the sound, tried VBR 2 pass – 40 minutes later – unsynced sound.
    What is going on?
    I have a brand new laptop running XP pro – dual core – 4 gigs ram. It should handle it. No other major programs are open.
    By the way- I would also like to deinterlace the footage at the end since this project is for computer/web viewin only. I have tried selecting everything as deinterlace – no fields (progressive) and no change either way.
    Please help!
    Mike Velte replied 17 years, 6 months ago 3 Members · 4 Replies
  • Jon Gulbrandson
    February 25, 2009 at 7:03 pm
    I had a similar issue once.. I recorded an event (over 25 hours DV footage) and used two portable audio recorders to capture audio in different locations..
    In post, I put it all together (it looked and sounded great) but I also had that sync issue…
    because the final edit was 2.5 hr long, i had to chop up the audio .wav about 10 times for each of the recordings, and sync it in the middle of each of the little ‘clips’ of audio…
    I just assumed that the recorder captured the audio at a different.. speed.. or “frame rate” so to speak.. so no matter what, premiere is going to see that the video is 10;00;00, but the audio for the same exact thing is really 10;02;00…
    I have no idea why.. but.. i also had to chop it all up to get it to match..
    Just re-read your post…. it’s out of sync on export? hmm… try using adobe media encoder if you’re using Export>movie… that might work..
    umm… otherwise, you may have to convert the audio to a different format…
  • Henry Johnson
    February 25, 2009 at 7:10 pm
    Thank you Jon,
    That is exactly what I had thought and that’s why I tried to dig around to see if there was a setting or configuration that would adjust the sound file for me.
    But I have not found anything. Now I thought I fixed the syncing problem by chopping up the sound but in export the sound is out owf sync again. Which makes this a nightmare- if I can sync in premiere but loose it in export.
    I am hoping there is a configuration issue- a rookie mistake somewhere in my file outputs.
    I have heard of timecode issues and that your diplay timecode or display in general can be off ( I acn’t remember the specific thread). That thread said if you do not have your timeline audio display in the correct format you will get syncing problems. That makes the most sense.
    There has to be a way to sync this sound. I am simply not doing something correct. 🙁
    I could simply try to splice it all together but I want to discover the underlying issue and solve this problem for good- because i am going to be doing this often now.
    Any help is truly appreciated.
    Thank you
  • Jon Gulbrandson
    February 25, 2009 at 8:05 pm
    Umm…
    Try diagnosing general premiere problems…
    I know that I did have some crazy problem when I was trying to output my audio/sync project.. and I ended up trying a whole bunch of things.. but clearing the Windows temp files actually fixed it.. (sounds stupid, i know.. )
    otherwise.. try using adobe updater to see if you have the latest version…
    otherwise.. try rendering the sequence by pressing “enter” and then watching it and see if it’s still sync’d…
    Otherwise.. (if you haven’t already done this) try exporting in a variety of different codecs… or give the Export>movie thing a shot….
    the only other thing I can think of is maybe your dropping frames on export… not sure if that’s possible, or how to fix it exactly..
    I know I might just try dragging some transparent video onto the timeline and adding a timecode to it.. just to see what happens…
    sorry i can’t be of more help
  • Mike Velte
    February 26, 2009 at 6:32 pm
    Soundbooth or Audition might do a better job with your audio. Open all video clips and export audio as 48,000 Hz/16bit and use those audio files to replace the ones in Premiere.
