Activity Forums Adobe Premiere Pro Premiere Pro CS3 Export Problem – Please help
  • Premiere Pro CS3 Export Problem – Please help
    Posted by Elliot Barrett on July 5, 2009 at 8:37 pm
    I’ve recently just made a 21 minute short film for my final year project at university. When I orginally exported it to Encore and made a DVD with it I had no problems whatsoever.
    However I am now trying to export it as an MPEG2 file, so that I can upload it to youtube. However whenenver I export it, some of the parts of the film which I made in After Effects and imported to PP are messed up.
    For Example I have a flashback sequence which starts halfway through it, and my dream sequence at the end of the film is just a black screen.
    The rest of the movie is fine, it’s just the parts which I did in AFter Effects. It also views fine in Premiere Pro, but the clips to show up as a black screen on the timeline for some reason.
    I would greatlly appreciate any help with this as it’s driving me crazy.
    My PC Specs:-
    Windows Vista SP3
    Intel Quad Core Q6600
    4GB Corsair RAM
    Geforce 8800 GTS
    Sound Blaster X-FI
    550 Watt Corsair Power supply
    I am using Adobe Premiere Pro CS3 and After Effects CS3 versions
    Elliot Barrett replied 17 years, 1 month ago 2 Members · 2 Replies
  • Stanley Flomin
    July 6, 2009 at 6:03 pm
    hmm…try checking to make sure your layer visibility is on in premiere(and check the opacity too)…if that doesnt work try throwing your after effect files into a new PR sequence and see if they render out fine. If they do then you know its something with the original sequence and maybe you can just copy the rest into a new sequence…if it doesn’t double check your AE file, maybe you have a layers visibility turned off or something on top of them….good luck!
  • Elliot Barrett
    July 7, 2009 at 4:29 pm
    How do you check the layer visibility?
    The opacity is at 100%. It also makes no difference if I put the clips into a new sequence.
    It’s incredibly weird, as it previews perfectly in the preview window.
    Not really sure what’s going wrong.
    Any further help would be greatly appreciated.
    Elliot Barrett
