Activity Forums Adobe Premiere Pro Premiere Pro CS 5.5 and MXO2 mini – Problems
  • Premiere Pro CS 5.5 and MXO2 mini – Problems
    Posted by Mark Parry on November 20, 2011 at 3:47 pm
    I made the switch to Premiere recently from FCP 7 (Apple, why?), and really like Premiere in general. However, I wanted to feed HDMI to an external monitor (Panasonic P55VT30). So I picked up a Matrox MXO2 Mini. I’ve had all kinds of issues with getting the video out of Premiere through the Mini. Incidentally, I tested the Mini with FCP and it works great.
    With Premiere, the audio is always slightly out of sync on either the computer monitor, or the plasma. The sequence will sometimes lose connection with the Matrox presets and give me an error. A 23.98 fps sequence won’t output to the plasma (though it’s just fine with FCP). I’ve followed the steps given to me by Matrox and that resets the system, but it’s a hassle to do all the time.
    Also, the sound output from the Mini is really high.
    Is anyone having good luck with the Mini and Premiere? Is there a better solution out there?
    Mark Parry
    Russ Blaise replied 14 years, 10 months ago 2 Members · 2 Replies
  • Russ Blaise
    November 29, 2011 at 3:04 pm
    Have you updated your Matrox mini driver to 2.3.3?
  • Russ Blaise
    November 29, 2011 at 3:12 pm
