Activity › Forums › Blackmagic Design › Premiere Pro CS 3 and Presets
Posted by Martin on August 13, 2007 at 6:28 amHi,
I use Premeiere Pro CS3 (german version) and Decklink Driver 6.4 (Win).
But I can
Dominic Osborne replied 18 years, 9 months ago 4 Members · 4 Replies -
Martin
August 13, 2007 at 10:46 amO.K. I found a solution by myself:
Please BM, solve this installationproblem for the non english user of BM cards .
Manual installation Instructions for Decklink presets in Adobe Premiere CS3.
To install the presets manual:
You must have a copy of Adobe Premiere Pro CS3 installed on your system.
1) Copy the “Black Magic Editing Mode.xml.xml” file, find in $(PROGRAMFILES)\Blackmagic Design\Blackmagic DeckLink\Premiere Support, into the following folder:
$(PROGRAMFILES)\Adobe\Adobe Premiere Pro CS3\Plug-ins\en_US\Editing ModesNote: If you have installed Adobe Premiere Pro on a localized (non-English) version of Windows XP, the “en_US” path will have a different name, such as “ja_JP” (for Japanese). In this case, install it into the “Editing Modes” folder within this folder.
2) Copy the files “BMDxxxxxx.prm”, find in $(PROGRAMFILES)\Blackmagic Design\Blackmagic DeckLink\Premiere Support, into the following folder:
$(PROGRAMFILES)\Adobe\Adobe Premiere Pro CS3\Plug-ins \en_USNote: If you have installed Adobe Premiere Pro on a localized (non-English) version of Windows XP, the “en_US” path will have a different name, such as “ja_JP” (for Japanese). In this case, install it into the “Editing Modes” folder within this folder.
3) Copy the folder “2.0” with its content, find in $(PROGRAMFILES)\Blackmagic Design\Blackmagic DeckLink\Premiere Support, into the following folder:
$(PROGRAMFILES)\Adobe\Adobe Premiere Pro CS3\Settings\en_US\.
You can rename there the foldername “2.0” to a name at your choice.Note: If you have installed Premiere Pro on a localized (non-English) version of Windows XP, the “en_US” path will have a different name, such as “ja_JP” (for Japanese). In this case, install it into the folder that corresponds to your language.
3) Restart Adobe Premiere Pro and click the New Project button. There will be new Presets in the 2.0 or renamed folder; choose the one that corresponds to the framerate in which your source video was recorded.
Kristian Lam
August 26, 2007 at 11:41 pmHi Martin,
We would like to investigate this issue. Could you please contact us at support[at]blackmagic-design.com so that we can send you some diagnostic instructions? Thanks.
regards
Kristian Lam
Blackmagic Design -
Dominic Osborne
December 6, 2007 at 6:11 pmWe’ve just installed Decklink Extreme PCIe cards after the older PCI models did not work with greater than 2GB RAM.
Premiere had no presets found, but these instruction have made it work, so thanks.
Now all I need to do is make After Effects work with the output – currently I have two options for Blackmagic video output in my video preview settings, and neither of them seem to work….
Dominic Osborne
Director & Head of Visuals
Eight Eyed Sea Bass Ltd
http://www.eesb.tv
