Activity Forums Adobe Premiere Pro premiere pro crashes :(
  • premiere pro crashes :(
    Posted by Omar Sleem on November 23, 2018 at 1:39 am
    hi guys
    hope u all r ok
    I ‘ve really got disappointed because of that and want you to tell me what do u think:
    premiere pro always crashes when i switch between workspaces, especially, when i switch to color workspace, or just try to open the comparison view.
    first, i thought that was because of the cc 2018 version, as Adobe itself confessed that the software may crash while switching between workspaces. but now i ‘ve upgraded to 2019 version and there is still the same issue.
    some buddy told me it’s all about hardware.. i’m using gtx 950 – core i7-6700 3.40 ghz – 32g ddr4 ram on win 10.
    so what do u think?
    thanks in advance
    Mark Thompson replied 7 years, 10 months ago 2 Members · 3 Replies
  • Mark Thompson
    November 23, 2018 at 10:41 pm
    I had the same problem in cc 2018, when I was using a new build pc.
    Then I upgraded to CC 2019 and the problem just seemed to go away. Unfortunately I never made a note of what I did exactly that fixed it. I should say I also upgraded to the latest CUDA driver. At the moment I don’t see this problem at all but I was furious when it happened
    Stretching my brain a bit, I think I had this problem in CC 2017 – it also just went away.
    What I did was get to Lumetri from the Effects Panel and so I just worked around the problem for a while.
    So, I suggest upgrading to the latest Nvidia driver.
    Just use Lumetri from the Effects panel for a while. They say the Lumetri Panel is just a remote control anway.
    Now why might this be a fix? It could be that there is some workspace setting that is not getting initialized properly upon first use. However by using Lumetri for a while it does get initialized and then you can use the Color panel.
    Also do a “reset to saved workspace”.
    Sorry it is not a more definite answer
  • Omar Sleem
    November 25, 2018 at 12:06 am
    thanks for your response, Mark
    that’s exactly what I did to work around the problem, I got the lumetri from the effects panel. sometimes i keep working in the standard editing worspace and add the lumetri panel from window menu. that does work with me but still, premiere crashes always when I open the comparison view.. you know how important is it. it’s irreplaceable.
    I have already updated the graphics driver to the latest version.
    so, what do you think about my hardware??
  • Mark Thompson
    November 28, 2018 at 7:09 am
    your hardware looks good.
    I have a 4k LG monitor, what size do you have?
    When I did have the problem, I could open on a 1440 monitor, also attached.
    I think it is a Software problem and should be reported as a bug.
    mark
