Activity › Forums › Adobe Premiere Pro › Premiere Pro Crash – How to begin debugging
  • Premiere Pro Crash – How to begin debugging
    Posted by Christina Rule on October 20, 2015 at 8:38 pm
    I am reaching out to my fellow Premiere people in hopes to save my sanity.
    Premiere crashes on me on a daily and I’m trying to figure out what exactly is causing the issue. I’ve tried re-installing, updating, cleaning off drives, clearing unused footage from projects, removing FXs and nothing seems to help. I am curious as to where I would start to actually try and find what is causing the program to crash. Is there a log I can go through?
    I’m using PP CC 2015 2015.0.2. release
    windows 7 professional
    intel r Xeon (r)
    96GB memory
    64bit
    thanks in advance
    http://www.christinarule.com
    Eli Coogan replied 10 years, 11 months ago 3 Members · 2 Replies
  • Jerry Wise
    October 20, 2015 at 11:06 pm
    you might try trashing your preferences.
  • Eli Coogan
    October 21, 2015 at 6:18 pm
    I’m in the same boat, but as far as possible solutions, I’ve encountered:
    – Uncheck “Sum multichannel outputs to Mono in Source Monitor” and “Maintain pitch while shuttling” to solve the source monitor scrubbing crash.
    – Yesterday, on my post, Kevin responded about using OpenCL instead of CUDA if you have it, and trying to check your permissions folders. Also, basically not having any other program open. The thread here:
    https://forums.creativecow.net/thread/3/970837
    – I’ve heard that if you’re starting a project on another computer and switching it over, instead of just opening it, you should start a new project and import it.
    Other than those, I’m still searching for a way to make it more stable. I’ve been crashing three or four times a day. Pretty frustrating.
