Premiere Pro CC skipping/dropping frames
So on Premiere Pro CC 2014 all my clips are skipping frames (only between 1 and 2) The clips play fine on any media player, but once in Premiere they skips frames, this also happens after exporting. Any ideas?
The sequence is correctly set up with the footage (same frame rate etc) and this is happening on multiple projects.
It must have started in the past few weeks but because it’s a subtle problem it was hard to notice.I’ve tried turning off mercury playback engine, turning off previews when exporting and rolling back my graphics card but no luck,
any ideas? I’ve attached a clip of it happening https://youtu.be/kwU0MbTPBoM
Will appreciate any help.
