Activity Forums Adobe Premiere Pro Premiere Pro CC no longer compatible with New Mac Pro running 10.9.3
  • Premiere Pro CC no longer compatible with New Mac Pro running 10.9.3
    Posted by Ben Silberfarb on June 3, 2014 at 12:41 pm
    Since the release of Mavericks 10.9.3 Premiere Pro will no longer run on late 2013 Mac Pro’s with AMD FirePro GPUs.
    Specifically: Using Premiere with 10.9.3 will cause glitching in playback (horizontal lines and computer freezing) as well as break your ability to export sequences. Contrary to rumors of work-arounds, at this time, there are NO KNOWN FIXES.
    It is on Adobe to acknowledge this and until a fix is found remove from it’s compatibility listing AND provide a general alert.
    Alexander Føsund replied 11 years, 8 months ago 22 Members · 75 Replies
  • 75 Replies
  • Andy Edwards
    June 3, 2014 at 7:29 pm
    Have you tried turning off OpenCL and using software only for exports. I know, not the answer you want to hear, but maybe a temp fix till Apple pushes out 10.9.4 and or Adobe pushes out a new update.
    Andy Edwards
  • Ben Silberfarb
    June 3, 2014 at 7:47 pm
    Hi Andy,
    Yes – this is a common suggestion, but unfortunately does not work. Note also that the beta release of 10.9.4 (available to developers of which I am one) does not fix these compatibility issues. Blackmagic’s Resolve has also been taken out by Apple’s recent update (10.9.3).
  • Andy Edwards
    June 3, 2014 at 8:47 pm
    Hi Ben,
    Ok, sorry not much help on my part then. Guess we are all on hold till the next Premiere update and or Apple pushes out a fix. I just time machined one of our new Mac Pro’s w/ 10.9.2 so I can go back.
  • Ericbowen
    June 4, 2014 at 3:03 pm
    I have others reporting 10.9.4 beta fixes the hardware acceleration on playback and export. Do you use 3rd party FX?
    Eric-ADK
    Tech Manager
    support@adkvideoediting.com
  • Ben Silberfarb
    June 4, 2014 at 4:03 pm
    All 3rd party plug-ins are disabled and still glitchy as hell with beta 10.9.4. Below screen grab of typical export errors.
  • Ericbowen
    June 4, 2014 at 4:52 pm
    The source monitor is just the player. There is no acceleration going on there anyway. This is something else. What media is that?
    Eric-ADK
    Tech Manager
  • Ben Silberfarb
    June 4, 2014 at 5:38 pm
    Yes – an exported source file with glitches from corruptions during export. The export was from an image sequence to 4k ProRes HQ. Most of the time Premiere will simply crash on export and not just time lapses/image sequences – most exports to ProRes.
  • Brad Bussé
    June 4, 2014 at 8:00 pm
    I started experiencing these problems after the 10.9.3 upgrade a couple of days ago. I was able to resolve by switching off the GPU in Premiere, quitting out, deleting Premiere prefs, deleting Premiere render files, emptying the trash (had to force empty with Onyx to get rid of one of the Adobe prefs), restarting. Then it works again.
    I’m also having some audio and stability issues in Premiere and Audition since the 10.9.3 update with my BMD Ultrastudio 4K. I tried rolling back the driver but to no avail so I took it offline until there’s a fix.
  • Kevin Monahan
    June 4, 2014 at 9:40 pm
    Thanks for reporting, Brad.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Kevin Monahan
    June 4, 2014 at 10:00 pm
    Hi Ben,
    [Ben Silberfarb] “Since the release of Mavericks 10.9.3 Premiere Pro will no longer run on late 2013 Mac Pro’s with AMD FirePro GPUs.”
    So sorry you’re experiencing issues. Others have also reported the problems you are having. However, everything is functioning normally for many users. That’s the vexing thing. We do know about the issues you mentioned and are working with our partners to get a fix out for those users ASAP.
    Kevin
    Kevin Monahan
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
Page 1 of 8
