Activity Forums Adobe Premiere Pro Premiere Pro CC First Clip Capture Out Of Sync
  • Premiere Pro CC First Clip Capture Out Of Sync
    Posted by Kevin Keegan on June 18, 2013 at 7:11 pm
    So I’m having an issue with capturing from a AJA KiPro on Premiere CC. I’m just trying to put it through it’s paces. I’ve created a AJA compatible sequence on FCP7 and output it onto our KiPro drive and loaded into the machine. I then logged two clips off of the drive and batch captured them. While the second clip captures perfectly in sync audio and video…the first clip the audio is behind by exactly 7 seconds. I’ve tried deleting and relogging the clip and still the same thing. The only way I’ve been able to get a first (out of multiple/batch) file to capture in sync is to capture the clip using the capture in/out button on the premiere capture interface.
    I’ve gone through the Adobe AJA Plugin manual and setup Premiere CC with the recommended settings.
    I’m on OSX 10.8.2 and Premiere Pro CC 7.0 on a Mac Pro with a KONA LHe Plus running 10.4.4 and the latest Adobe/AJA plugin pack.
    I know the software is brand new but just wanted to see if anyone else can replicate this or limit it to maybe a KiPro issue.
    Walter Biscardi replied 13 years, 2 months ago 3 Members · 3 Replies
