Activity › Forums › Adobe Premiere Pro › Premiere Pro CC External Monitor Problem
  • Premiere Pro CC External Monitor Problem
    Posted by Simon Roughan on June 20, 2013 at 2:24 pm
    Hi All,
    have upgraded everything to CC, and so far so good EXCEPT…
    I can’t get the external monitor working. I have an BM Intensity Pro card. I have downloaded and installed all the new BM drivers. I see the card in the “Playback” preferences. I make the tick in the Blackmagic box, but no picture on the monitor. Just in case you think I havn’t plugged it in, or some such thing, I have a picture in the monitor with AfterEffects. Just no RAM preview, but thats another story.
    Any ideas?
    Thanks in advance
    Simon
    You know I’m born to lose, and gambling is for fools, but that’s the way I like it, baby. I don’t want to live forever!
    Gerry Cast replied 10 years, 6 months ago 5 Members · 15 Replies
  • 15 Replies
  • Kris Merkel
    June 20, 2013 at 4:02 pm
    If you open CS6 do you see your preview monitor?
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
  • Mike Squires
    June 20, 2013 at 4:12 pm
    I had the same problem initially. Un-check the Blackmagic card, reboot the computer, start PPro, and then check it again.
    This was driving me nuts yesterday trying to figure it out.
  • Gerry Cast
    October 15, 2013 at 11:50 pm
    Is the Black Magic Intensity Pro card working with Premier CC and AE CC still?
    Just wondering before I bought it as I am reading lots of horror stories, and B and H won’t give a refund on this item should I buy it.
    I’m running Win 7 Pro in a stable, video only, fast PC.
    Thanks.
  • Mike Squires
    October 16, 2013 at 1:03 pm
    I’m pretty sure it still does. I’m currently using the Ultrastudio USB 3.0, Shuttle USB 3.0, and Mini-Recorder Thunderbolt with CC, and they all work fine.
    Note, don’t use the newest drivers from Blackmagic, they’re screwed up. Most use version 9.5.
  • Gerry Cast
    October 16, 2013 at 1:18 pm
    Thanks, Mike.
    What are the key differences in your interface and the Intensity? I have a Win 7 machine.
    Prices seem comparable, but I’m was just rushing to read about it and couldn’t finish.
    Thanks again.
  • Mike Squires
    October 16, 2013 at 1:22 pm
    The Intensity Pro and the Intensity Shuttle are basically the same, they both accept analog and HDMI inputs, though one is an internal card, and one is external (via USB 3.0 or Thunderbolt).
    Since I travel quite a bit, I have to edit on a laptop, hence the external version.
    EDIT: btw, I’m running Win 7 also.
  • Gerry Cast
    October 16, 2013 at 2:37 pm
    Thanks.
    I keep reading bad reviews of the Shuttle, saying that if you don’t have the older USB 3 Chipset, see below. I was wondering how old is your motherboard?
  • Mike Squires
    October 16, 2013 at 2:48 pm
    I’ve personally had good luck with several laptops from Asus (the G53, G74, and G55). My G55 also has a Thunderbolt port, which works fine also with the Mini-Recorder.
    We also have a Dell Optiplex tower that we put an internal USB 3.0 card in, and it works fine also.
    The key is how the USB 3.0 chipset is implemented by the manufacturer. I’ve gotten lucky that Asus does it correctly.
  • Gerry Cast
    October 16, 2013 at 3:00 pm
    Thanks.
    I’ve got an Asus Maixumus 1V Extreme-Z, so I guess I should give it a try!
  • Mike Squires
    October 16, 2013 at 3:01 pm
    If you plan on going with a USB 3.0 version of the Shuttle, you should be fine.
    Also, make sure to use the newest USB 3.0 drivers directly from Intel, not from Asus.
