(PREMIERE PRO CC 2018) .mov File Only Showing Up as a .wav File
Hi all! I’m having this issue with this one .mov file where it only shows up as an audio file when inserted into Premiere Pro. Any thoughts? Here’s what I’ve tried so far:
1. Importing it into Adobe Prelude and then into Premiere. (It plays perfectly in Prelude, but not so much in Premiere.)
2. Checked to make sure that it plays through quick time. (It works perfectly.)I know that the file itself is not corrupt as we use this video for a weekly livestream through Pro-Presenter.
I’m not sure what the solution may be, but I would greatly appreciate your suggestions. Thanks!
