Activity Forums Adobe Premiere Pro Premiere Pro CC 2014 and Intensity Shuttle for monitoring issues
  • Premiere Pro CC 2014 and Intensity Shuttle for monitoring issues
    Posted by Michael Duff on April 18, 2015 at 4:56 pm
    I just got a Blackmagic Intensity Shuttle thunderbolt so that I can monitor output from CC2014 to an HDMI monitor.I’m working on a MacBook Pro Retina w 16gb ram.
    I can’t seem to get the output to consistently work. Mostly I just get a blue screen. The footage I’m working with is .MXF files from a Sony FS7.
    The only way I can get it to display is if I create a new sequence with the following settings
    Note that this only works when I set fields, even though my footage is progressive. Also, if I have an existing sequence and I modify the settings to match this then it will not work.
    Also, it never works for the source window.
    Is there something obvious I am missing??? Is anyone using an intensity shuttle successfully and if so how do you work with your sequences.
    Thanks for the help,
    Michael
    https://www.duff.tv
    https://www.gmbfilms.com
    Michael Duff replied 11 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
