Activity Forums Adobe Premiere Pro Premiere Pro Capture Card , Hard Drives, Computer
  • Premiere Pro Capture Card , Hard Drives, Computer
    Posted by S2videos on January 21, 2007 at 10:43 pm
    I am researching setting up a Premiere Pro System. Couple of questions:
    1) What type of capture card do you recommend?
    2) Do you simply use a large hard drive inside the computer or external drives… some type of array?
    3) What type of computer do you recommend? I have seen the min requirements, but am curious as to personal preferences?
    Thanks All!
    Aanarav Sareen replied 19 years, 8 months ago 3 Members · 2 Replies
  • Steven L. gotz
    January 22, 2007 at 1:44 am
    The type of PC is pretty much up to you. I bought a couple of Dell’s until this last system that I had built for me by a PC guy.
    There is no need for a special capture card unless you are capturing analog. In that case a Canopus AVDC card or external would suffice. Canopus used to have the DVStorm2 which worked until Premiere Pro 2.0, then Canopus decided to not support Adobe and force their users to Edius.
    You can usually get by with two internal drives. One for programs and one for projects and video. A third drive for a scratch disk is handy. Forget the externals except for backup, unless your new PC has an external SATA (ESATA) port.
    If you will be editing HDV, get more power and bigger drives, and probably go with a two drive RAID0 for your video.
    Steven
    https://www.stevengotz.com
  • Aanarav Sareen
    January 22, 2007 at 9:56 pm
    [S2Videos] “2) Do you simply use a large hard drive inside the computer or external drives… some type of array?”
    I have used both types of drives. Since my main edit system is a laptop, I use fast external drives without any issues at all.
    – Aanarav
