Activity Forums Adobe Premiere Pro Premiere Pro – Can’t put dynamic linked AE comp into my timeline
  • Premiere Pro – Can’t put dynamic linked AE comp into my timeline
    Posted by Bradley Houshour on October 4, 2012 at 8:37 pm
    I have CS6. I’ve got a Premiere session open and working on a sequence. I just finished an AE comp.
    From inside of Premiere, I go to Adobe Dynamic Link – Import AE Comp. It imports it into the project pane, but when I go to drag it into my Premiere Pro timeline, it gives me the “no” symbol of the circle with the dash through it. I work in Premiere and AE a lot, and this is the first time I’ve had this problem. No matter how I try to get it into the timeline, nothing works.
    Does anyone know why this is happening?
    Lukas Krueger replied 9 years, 5 months ago 5 Members · 6 Replies
  • Alex Udell
    October 4, 2012 at 8:53 pm
    Does it load to the source viewer?
    Alex Udell
    Editing, Motion Graphics, and Visual FX
  • Bradley Houshour
    October 4, 2012 at 9:09 pm
    Yes, it loads in the source viewer. I can see it playing, but I can’t drag it into the timeline, nor can I use any of the source viewer functions like insert or overwrite.
  • Alex Udell
    October 5, 2012 at 4:33 pm
    any sequence?
    any project?
    just trying to isolate the behavior…
    Alex Udell
  • Evan Jenkins
    August 2, 2013 at 5:57 am
    SOLVED.
    I had the exact same issue. Then I remembered that some of the video in my timeline had already been exported to AE with the right click ‘Replace Footage with After Effects Composition’. I forgot that once you do that, you can no long drag a sequence from PR to AE and get the dynamic link working again. Therefore, all I had to do was just delete a few of the videos in the timeline that I had already sent over and then it worked.
  • Justin Scott
    March 21, 2016 at 6:56 pm
    The problem with not being able to import your AE comps into your PR timeline is most likely that your main “V1” was not selected as a target track.
  • Lukas Krueger
    February 28, 2017 at 8:13 pm
    I ran into the same problem and maybe yours is just like mine. I worked on a film in AE and PP at the same time and already imported one Sequence from PP into the AE Project. Then i created a comp in that AE Project and imported it back to PP. Then i couldnt drag this Comp into the timeline (Stop symbol Cursor). I guess (!!), it is some kind of security, that neither of the two programs run into recursive errors. (Means you import A in which B is already imported in which A is already imported in which is B etc…
    TLDR: You have to create a new AE Project, in which your current PP Project is NOT already imported in. Then it all works fine again. I hope it helps anyone.
