Activity Forums Adobe Premiere Pro Premiere Pro Automatic timecode graphics??
  • Premiere Pro Automatic timecode graphics??
    Posted by Maggie Hart on July 9, 2012 at 8:06 pm
    I work a lot with L3/SS in After Effects and bringing them over to Premiere. I use a spreadsheet to tell me what timecode each graphic should appear. Is there some sort of script, or some way that I can have Premiere automatically place the graphics at their proper timecode in the timeline? That would save tons of time!!
    Angelo Lorenzo replied 14 years, 2 months ago 2 Members · 1 Reply
  • Angelo Lorenzo
    July 9, 2012 at 8:29 pm
    I would take the sequence from Premiere’s bin and drop it into After Effect’s bin. The sequence will come in a one block (like a nested sequence/pre-comp) that you can drop into a new composition with your titles. I would then see if there are any After Effects scripts to do what you need.
    The sequence is dynamically linked, so if you make changes in Premiere hit save and then go over to AE, right click the sequence in your bin and hit “reload”. If you changed the length of the sequence, you may need to change the length of the comp it sits in as well.
    Premiere Pro, as it stands, doesn’t have the scripting capability AE does and I’m sure there are a dozen variations of scripts for what you need to do.
    Angelo Lorenzo
    Fallen Empire – Digital Production Services
    RED transcoding, on-set DIT, and RED Epic rental services.
