Activity › Forums › Adobe Premiere Pro › Premiere Pro and music vs Final Cut Pro X and iTunes
  • Premiere Pro and music vs Final Cut Pro X and iTunes
    Posted by Yair Bartal on November 18, 2014 at 5:34 am
    Final Cut Pro X has an easy access to music via an iTunes built in button.
    Is there a similar solution (plugin?) for Premiere Pro CC?
    Steve Connor replied 11 years, 10 months ago 4 Members · 4 Replies
  • Kevin Monahan
    November 18, 2014 at 7:23 pm
    Hi Yair,
    There’s no button, per se. However, you can drag in songs from the iTunes browser right into the Premiere Pro project panel, which I think is pretty cool (and not very well known).
    The only thing you have to be wary of is that songs bought from the iTunes store are not supported, but your personal .MP3s, AIFFs, music you create in GarageBand are.
    Kevin
    Kevin Monahan
    Support Product Manager—DVA
    Adobe After Effects
    Adobe Premiere Pro
    Adobe
    Follow Me on Twitter!
  • Yair Bartal
    November 18, 2014 at 7:39 pm
    Thanks Kevin for the info.
    I’m on PC and in the meantime I’ve found a plugin for Premiere Pro here:
    https://www.smartsound.com/sonicfire/downloads
    I wonder if there are similar or better alternatives.
  • Paul Neumann
    November 19, 2014 at 3:31 pm
    [Kevin Monahan] “which I think is pretty cool (and not very well known”
    You got that right. FCPX has paid for itself with just the sound effects I’ve gotten out of it. I drag things from all sorts of different programs into the Adobe apps and more times than not it works fine. Like Power Point to InDesign or Illustrator to Power Point. So much so that I’m a little surprised when it doesn’t.
  • Steve Connor
    November 19, 2014 at 4:46 pm
