Activity Forums Adobe Premiere Pro Premiere Pro and MC Transport
  • Premiere Pro and MC Transport
    Posted by Thomas Frank on December 16, 2010 at 1:43 pm
    Since Adobe has CS5 Premiere Pro out and Apples Final Cut Pro it still in the stone age! 😉
    I was planning on to see how Premiere works, while I am working on this HD project.
    So I was wondering if there is a Config file that I can download to use it with the Euphonix MC Transport?
    Darius Wilhere replied 15 years, 4 months ago 2 Members · 5 Replies
  • Darius Wilhere
    May 19, 2011 at 4:14 pm
    Hi Andree,
    I had the same problem but figured it out, you can see it here https://wp.me/p1hbRg-e
    or I’ll paste it here for you as well:
    I recently made the switch from PC to MAC for the long-form documentary I’m making. A decision that so far, I definitely regret. But more on that later.
    For the moment I thought I’d start posting notes about problems I’ve run into and solutions to them that I’ve found in case any one else runs into these same problems.
    I purchased the Avid/Euphonix Transport for use in my editing as having a jog/shuttle definitely speeds things up remarkably once you are accustomed to them.
    However I didn’t notice that Adobe Premiere was not supported and this is my editing program of choice at the moment although I do have FCP and Media Composer 5.52.
    I googled around and even contacted Euphonix/Avid support and no one seemed to have a solution.
    In frustration I then ordered a Contour Shuttle Pro v2 (which is sort of like downsizing from a Porche to a Honda. Both great cars, but which one would you kick out of bed first? Exactly.)
    So while waiting for international shipping I tried a bit of a wild idea and I installed the drivers for both the Bella Pro Premiere keyboard (which I don’t have) and the Contour Shuttle and then began customizing the MC Transport commands to match the command keys in Adobe Premiere.
    As a note; you might not need to do this on your system. I’m using a Mac 12 core and this workaround only worked once I installed those drivers but logically speaking you shouldn’t need to do it.
    And hey! It works!!!!
    Some things aren’t as perfect as they are in Avid or FCP such as the shuttle wheel shifting to different speeds smoothly. But damn! The jog wheel works perfectly.
    Customizing the Soft Keys just involves ensuring that Adobe Premiere Pro CS 5.5 is open and then choosing the soft key around the wheel and once it is highlighted in the EUCON controller, then assigning a KEY command.
    For example your center three keys above the jog wheel should have J, K, and L assigned accordingly.
    And however you wish to customize it after that. I use for cutting at timeline (CTRL + K), next edit (page down), previous edit (page up) and it is working like a charm.
    All the other soft keys including shift command respond the same.
    To program the jog wheel. Select it and choose Command, select Wheel from the drop down, then select jog right and choose special command and pick “right arrow” and then repeat for select jog left and choose special command and choose “left arrow.”
    The shuttle you have to choose the shuttle and again add a wheel command and then in choose shuttle and create a new shuttle wheel command. Then from shuttle drop down, choose for Section 0 add key and set it to K (stop), then for Shuttle Section 1 add L key once and for each shuttle section add one more L key. Shuttle section 7 has LLLLLLL assigned to it.
    For the shuttle -1 Section choose J and for each minus section following that add one more J.
    It’s not perfect but it certainly does what I need it to do!
    Hope that helps anyone else out there.
    Best,
    Darius
  • Thomas Frank
    May 19, 2011 at 5:38 pm
    That’s really cool! Could you provide me with the confit file? 🙂
  • Darius Wilhere
    May 19, 2011 at 5:54 pm
    Hi Andree,
    No problem…do you happen to know where I could find the configuration file! Sorry, new to the MC Transport device and software.
    Best,
    Darius
  • Thomas Frank
    May 19, 2011 at 6:33 pm
    You should be able to save your config, like back up from Eucom.
    Oh by the way I would also go with the Porsch!
  • Darius Wilhere
    May 19, 2011 at 9:02 pm
    The config file is here: 2370_eucontrol.cfg.zip
