Activity Forums Adobe Premiere Pro Premiere Pro (Adjustment Layer and Title limit -11hrs)
  • Premiere Pro (Adjustment Layer and Title limit -11hrs)
    Posted by Alex Golo on March 13, 2015 at 9:46 pm
    Hi:
    A friend needs to edit a 20 hour endurace race footage and needs to add some effects, titles, timecode etc.
    He is finding the limit to be 11 hours for each adjustment layer and premiere title. You can’t extend the adjustment layer or titles past 11 hours? Is there a solution to this? For example if you add a timecode to an adjustment layer to overlay the clips it will reset with each break in the layer….
    Any solutions to have titles as a single clip for 20 hours?
    Alex Golo replied 11 years, 6 months ago 2 Members · 2 Replies
  • Tero Ahlfors
    March 14, 2015 at 10:29 am
    [Alex Golo] “Is there a solution to this? “
    Make a copy of the layer?
    [Alex Golo] “For example if you add a timecode to an adjustment layer to overlay the clips it will reset with each break in the layer….”
    You can set a manual offset to the timecode effect.
  • Alex Golo
    March 14, 2015 at 2:29 pm
    Thank you, but is there a wat to extended timecode past 12 hours?
    For example when timecode reaches 12-hour mark wwhen added adobe media encoder it just stops counting. The timecode limit seems to be 12 hours while premiere timeline is 24-hour limited….
    Any ideas?
