Activity Forums Adobe Premiere Pro Premiere Pro 6.0.5 – m2ts no audio/sound
  • Premiere Pro 6.0.5 – m2ts no audio/sound
    Posted by Jackson Redshaw on July 8, 2014 at 8:54 am
    Hey,
    Having an issue importing m2ts files into Premiere Pro. They import with no audio. I’ve tried a number of fixes that I have found on Google with no success.
    Things I’ve tried:
    1. Re-installing Premiere
    2. Updating Premiere (Currently running 6.0.5)
    3. Changing the file locations to be on the same drive as Premiere
    4. Changing the file names to include .m2ts
    Is there anything I’m missing, besides converting all the video files? My Sony imports m2ts onto the computer, so it’s going to be tedious and time consuming to convert every single video file I use.
    Cheers
    Jackson
    http://www.youtube.com/MITLRproductions
    Chris Gu replied 11 years, 9 months ago 4 Members · 5 Replies
  • Chris Tompkins
    July 8, 2014 at 11:36 am
    Can you convert first?
    Chris
  • Paul Neumann
    July 8, 2014 at 12:53 pm
    What happens when you import them into After Effects? Prelude? Check that out.
  • Jackson Redshaw
    July 9, 2014 at 5:42 am
    I already stated about converting them?
    They work perfectly in After Effects and Prelude.
    Jackson
  • Paul Neumann
    July 9, 2014 at 5:57 pm
    So, just for grins, make a subclip from one of your clips in Prelude and send it to PPro.
  • Chris Gu
    December 1, 2014 at 12:17 pm
    People who are using M2TS files with Adobe Premiere Pro(especially CS6, CC7) often have the similar problems Premiere Pro missing audio track for M2TS files.
    There are 3 ways that might help you resolve your work- Premiere Pro, M2TS files, metadata and no audio:
    1. Install an earlier version of premiere pro like 4 – 5 depending what version fits what you do……(DO NOT UPDATE!!!)
    2. As far as I know import the ENTIRE CARD, very important, all the files from your card to your PC/Mac, the metadata should be located somewhere in a folder within the card, it’s not on the .mts file.
    3. If you only get the single .M2TS video, you can choose to change M2TS clips into another format for Adobe Premiere Pro and relink against the version. It will get the audio back into Premiere. Might be a bit time consuming but it works.
