Activity Forums Adobe Premiere Pro Premiere Pro
  • Premiere Pro
    Posted by Matthew Stewart on March 26, 2012 at 11:33 pm
    I was wondering what would be the best sequence setting for editing a slideshow of JPEG images around 4000 x 2000 pixels in premiere pro? Is there a way I can edit the images without having to render them?
    Matthew Stewart replied 14 years, 5 months ago 2 Members · 2 Replies
  • Ann Bens
    March 27, 2012 at 9:55 am
    I would make a sequence that is the same as the output size.
    Render as in red line turning to green or export?
    The images are jpeg so you will have a red line.
    Don’t use the preview files, most of the time you will end up with the wrong codec.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Matthew Stewart
    March 27, 2012 at 11:57 pm
    render as in red line turning green. Which codec do you think is the best to use for jpegs? I guess that should have been my original question. I am using final cut right now instead, but I am still curious about which codec would work best in premiere. Are the preview files the saved rendered clips?
