Activity Forums Adobe Premiere Pro Premiere Pro 2.0: repositioning a clip on the timeline
  • Premiere Pro 2.0: repositioning a clip on the timeline
    Posted by Sivart123 on August 3, 2006 at 7:45 pm
    HELP. I have been using adobe premiere 6.5 and now i am using premiere pro 2.0
    I am used to draging and droping a clip in my bin and when I put the new clip between two clips on the timeline the clip to the right is supposed to move over… well in premiere pro 2.0 it is not doing that… is there a setting i need to change? please help!!!!!!!!!!! tminchew@msn.com
    Troy Murison replied 20 years, 1 month ago 2 Members · 1 Reply
  • Troy Murison
    August 4, 2006 at 12:02 am
    Try holding the Control key down after you start dragging
    the clip. It should make a little arrows indication as
    you position it at an edit boundry in your target track
    and shift everything down after you drop it. At least
    that’s how it works on my system.
    -Troy Murison
    Seattle, WA
