Activity › Forums › Blackmagic Design › Premiere Pro 2.0 crashes with Intensity Pro
  • Premiere Pro 2.0 crashes with Intensity Pro
    Posted by S. Marcotte on April 6, 2009 at 4:01 pm
    The crash occurs on import. Time and time again. No error message. Premiere Pro simply vanishes from sight. I’m on XP Service Pack 2, Intensity Pro drivers 2.1.
    All is well when monitoring with After Effects Pro 7.0. No problems whatsoever.
    If anyone recommends updating drivers, please include a link. Thanks you.
    S. Marcotte replied 17 years, 5 months ago 2 Members · 2 Replies
  • Scott Thomas
    April 6, 2009 at 4:56 pm
    Does Premiere still crash if you uninstall the drivers for the Intensity?
    If the Intensity is working OK with After Effects, I would be less likely to blame it for Premiere’s problem.
  • S. Marcotte
    April 6, 2009 at 6:14 pm
    PP2 does, in fact, run fine if I uninstall Intensity. But I seem to have solved the issue but downgrading to previous drivers, specifically 2.0.
    It seems OK so far.
