Activity Forums Adobe Premiere Pro Premiere Pro 2 Problem
  • Premiere Pro 2 Problem
    Posted by Shay Willard on November 18, 2007 at 7:46 pm
    I just went on thanksgiving vacation and brought my PC home to get some editing done. At school I have a dual-monitor set up, but decided to only bring one home for sanity reasons. Upon setting up the PC, I started a new file and captured some footage (well, about 55 minutes of footage). When I came back, I couldn’t find the footage anywhere on my computer, and when opening the file back up again, Adobe would crash. I can make new projects, but cannot close and reopen them – I get the “Loading project” bar, see the project window for about a second before Adobe closes, not even giving me an error window. When I have a new project open, if I tried to move the window before re-setting the window style (for a one-monitor editing setup) it would crash, so I figured it must have something to do with the second screen suddenly missing. But it seems like an extreme error for just a missing screen.
    I would re-install it, but the install disc is back at College, and I can’t even repair it without the disc. I’m running Windows XP and Adobe Premiere Pro 2.0
    Any ideas?
    -S
    Shay Willard replied 18 years, 10 months ago 3 Members · 6 Replies
  • Blast1
    November 19, 2007 at 5:19 am
    Did you redo the display properties before you started any programs?
  • Shay Willard
    November 19, 2007 at 5:30 am
    Yeah, luckily my display settings set themselves to the correct set. I just double checked, and everything is how it should be.
  • Jeff Brown
    November 19, 2007 at 3:32 pm
    If you right-click on the “My Computer” icon, select “manage”, then go to “Event Viewer”, and look under Application and/or System, you may find an error log from whatever is causing the problem.
    Might help,
    jeff
  • Shay Willard
    November 19, 2007 at 4:32 pm
    Nope, unfortunately no record of any errors from Premiere Pro 2
  • Blast1
    November 19, 2007 at 6:01 pm
    Problem is when you move computers anything can happen, have you reseated the memory chips and cards? run any error checks, like memory checks, disk checks, etc??
  • Shay Willard
    November 19, 2007 at 6:44 pm
    Every other program I have works great – including other Adobe programs I’ve run across two screens, like After FX. But, no, I haven’t ttried reseating anything yet. I guess I’ll give that a try.
    -S
